Hi guys,
Just exploring my options here. My Stag failed its MOT on the track rods, but the tester said it was difficult to detect whether the movement was in the inner or outer ball joint. I am changing both outer track rod ends, although I can only detect movement in one of them. that leads me to think that the inner one on the other side might be a bit slack.
My question is, what wears? The inner ball joints don't appear slack, but do tighten up in places as you move them around. The outer half of the ball joint - from what I can see is designed as metal to metal and the inner half has a nylon/plastic cup with a spring behind it. I was expecting the metal to metal bit to be the bit that wears, but the only bits that are available are the inner cups and associated lock washers. I have ordered those bits, but the unavailability of the other bits surprises me, or do they just not wear out?
