Kenlow
    Kenlow
    Hi
    Just to let you know I have been working on a friends Stag and he now wants me to fit a Kenlow fan, well I rang Kenlow up as they are not to far from me and after reading the good coments on here about the new twin speed 14" fan (thanks Dave) I gave them a call and found them very helpfull in fact if you are thinking of fitting one at the moment they are offering a discount to Stag Owners Club members, as I said I had read about it on the S.O.C Forum.
    So ask for sales and for Jeff Handover who will also tell you what options you can have with the kit, he also said this fan is good enough to run on it's own if you want to go down that route
    Sorry the tel No 01628823303 Rec Price Over£200 Stag Owners Club £169 no connection just well pleased with the service and thought I would pass it on.
    Happy Motoring
    Fitted that exact fan myself recently, works a treat. I used the "L" shaped aluminium bars to mount it as I don't like putting those fans on with the thru-rad fittings. Stag rads seem to have staggered (sorry) tubes and they just won't stand up to the Kenlowe fittings. Also had to be quite careful pushing the temp sensor into place.
    You can wire directly across to the battery for the power, but I would recommend using a big (bigger than 30 amp as they just blow on startup) or "Maxi" inline fuse direct from the battery terminal. I used a 60A one, and that protects the +ve line up to inline fuse which is built into the Kenlow controller loom.
    You can't be too careful with wires coming directly off the battery..........
