This may be a stuoid question but, do these gauges after removing bleed themselves?
I removed my oil gauge as I just cant see it when illuminated compared to the other dials. I broke the green shield off inside, whcih is just a tiny sheet of geen next to the bulb. I can now see it, except the oil pressure readings are so long since. The needle is not fowling the dial that I can see and where I used to have reading on idle of between 40-50 when cold on idle, I will be lucky if it goes up to 30 when revving the engine from cold.
Is this aid does anyone think as teh pipe was removed for the job?
Any commets or advice much appreciated
Alan, are you there?
Andrew
Andrew
