I know this is a funny question but as this is my first stag and I am < 20 miles in the car since I bought it 2 years ago itis quite obviously different handling than with a modern car.
Firstly when I start the car I need 50% choke to accelerate away. How should one get thecarinto Drive ( automatic box I shouldsay ) as I get quite a large thump as it engages. I tried psuhing the choke in to reduce the revs but then I need the choke out to accelerate away whilst still cold. Now to operate the choke cable without snapping it one must push the accelerator slightly so that the choke comes out ok. I think you see my issue.
I also had a couple of times tonight when I engaged drive from cold and nothing was selected. After moving the selector a couple of time through the options it then engaged. Could this just be lack of use?
Once the car is warmed up, I still find the gear changes to be a little thumpyeven when no choke is applied. Is this normal?
The last issue is regarding whengear3 is selected. As 50KPHis th espeak limit in town, the stag seems to want to go into top at 60KMH this is a bit of a pain as I must accelerate to 60, foot off the accelerator and then she changes down after a couple of seconds. Is this normal behaviour? Can I ajust whentop is selected?
Lastly I checked the auto box fluid level and noticed it was at themin mark so I needtotop it up. Where does one add this fluid? The fluid in mine is pink is there anythingspecial I should buy to put in.
Sorry for the long questionarre and I appreciate the comments of others who have an automaticStag. I will obviously searc out someone over here to have a go in theirs to see the difference but until then I would appreciate any advice from you guys.
