Having another play with my overheating and pressurising motor today. Firstly took the rad off and flushed it through, it wasn't actually that bad and the water that came out was pretty clean. Then as a thought i went round and checked the head bolts. The rear lower bolt on the offside head wasn't tight...in fact it was loose! i thought first the bolt had snapped as it turned so easily. It did tighten up readily. I have checked the others on that block 3 were i reckon around 10 maybe 20 ft lbs certainly not tight. I have taken them all up to 40 ft lbs and run the motor to get it warm (around 60 degrees) and im going to let it cool right down. Probably tomorrow if i get chance i will try and push them up to 55.
Im having debates about whether this would account for my overheat/pressurisation issues and whether running it like this would have caused further damage. I suppose the one good thing is that the bolts should all come out if i decide to lift the heads to do the gaskets.
I know the motor was rebuilt in 1991 so the heads have certainly been off once albeit 20 odd years ago. Its only done 20k since the rebuild
