hi i have just bought 72 stag with 3.5 rover engine but the ride height is not right any advise would be helpfull allan
rover conversion
Hi Allan and welcome to the forum.
Firstly don't get put off by people whining about a Rover v8 Stag not being a proper Stag (there will be a few
). I'm sure any Tv8 owners who have been plagued by HG issues would be more sympathetic th the idea!
As I am sure you already know, the Rover 3.5 is a very light engine. I had a 4 cyl MGBGT then traded up to an MGBGTv8 which was considerably lighter then the 4 cyl. At the risk of being obvious, you need to look at suspension mods, not only from a ride height perspective but also from a balance/handling point of vbiew as well. I'm sure there will be plenty of people with experience of Rover v8 conversions who will be able to give you more helpful and specific guidance.
Hi, Allan. Welcome.
When you say 'ride height' do you mean front or overall?
If front then it is likely that whoever did the conversion didn't change the front springs. As Martin says, the RV8 is much lighter than the TV8. I am sure someone will advise which springs are needed.Dave
And a large eff off radiator and a huge life insurance policy....Originally posted by martin View PostI used to know a couple of beetles that used the RV8, it's only 40 lbs heavier than the original engine, and just hung on the four bolts on the bell housing, no rear mounting at all, very little modding needed and the engine cover moved back on hinge extensions. Martin.Last edited by GDPR; 22 August 2012, 15:52.
A friend of mine in the VW trade once acquired an RV8 early Bay Window Camper. Interesting was one way to describe the experience (considering most Campers could barely take the skin off a rice pudding!). It looked little strange on the front though with it having a grille!Originally posted by martin View PostTPFT didn't cost much then
One had the rad leanlng back in the spare wheel well, and four small grills set into the bonnet, seemed to work, needless to say it wasn't as fast as he'd hoped, the gear ratios and the swing axles saw to that
M
