Pacet fans
    Pacet fans
    Hello,
    I going to invest in an electric fan My nerves can't take it when I get stuck in a traffic Jam,My cooling system is healthy this is just a precaution. I have been in touch with Pacet fans and this is what they
    recommended. Do I need anything else and can a novice like me install it
    For your Triumph Stag we recommend a 16” puller fan complete kit, TCF1611P for £150.00 inclusive of VAT, delivery ex stock
    Eva – Sales
    Hiya, in practical terms, you can't install a puller fan, there isn't room, unless you rip out the viscous. Have a look at Stafford Vehicle Components site, prices are good, and there are two grades of Pacet fan with comparative figures. As to controlling it, that depends on how much you want to spend. Martin.
      Thanks martin,
      All I want is a backup to help out if needed, anyone got any pictures or details of their set up
        I have a 16" pacet blower only with a stagdad external water pump Happy days will convert to a puller when i pull gearbox out this winter
          I just fitted a 14" Twin speed Kenlow pusher mounted in front of the rad. (looks stock unless you look hard)
          Works perfectly, and the boost speed is very powerful. Lets you have a reduced current draw for "normal" situations, then go to boost if the temp rises a further 5degrees C from the nominal switchng in point. Easy one -wire manual override if you want it.
          Mounted on the right angled ally rod system as I don't like the "ties through the radiator core" system.
          I'm lovin' it. Perfect temp control.
            I fitted a small fan out of a VW transporter van which i had knocking about the garage, used 2 small brackets to mount the top of the fan to the back of the radiator bolts and drilled a small hole into the lower panel and fitted the bottom mount through that, simple on/of switch on the dash. Its not made much difference to mine as it was overheating anyway but would probably help keep it a bit cooler. Hopefully a couple of pics attached...DSCF5543.jpgDSCF5544.jpgDSCF5545.jpgDSCF5548.jpg
              I got mine from Stafford Vehicle Components i`ve fitted a pacet 14" fan and theromosat which was around £130 the stat is set a 90 degrees very rarely cuts in, it`s a very simple kit to install and works well.
              Adrian
                My Pacet fan is fitted in front of the radiator and it was pretty simple to install. The only mod I have made is to connect a green warning light in the dash (where the oil light used to be) that comes on when the fan starts so that I know it is working.
