Does anyone know the correct fuse ratings/where I can find them listed? It seems each Stag I look at is different? Ta Andy
Correct fuse ratings ?
In the owners manual and work shop manual, I'm sure it will be online somewhere too.
important thing to remember, the fuse ratings listed are blow ratings, not continuous, with Lucas fuses.
Modern fuse ratings are continuous, not blow, for example blade fuses.
The problem comes in that you can buy glass fuses in either rating, and you don't want to fit say an incorrect 10 amp fuse rated continuous (20 amp blow), when a correct 10 amp fuse rated blow (5 amp continuous) should have been fitted.
MikeMike.
