Hi guys,
Wondering if I could have the advice of the Stag collective? I was trying to remove the radiator at the weekend and cannot remove the fan cowl - I was able to remove the nearside nut from the bolt easily, but the offside bolt ended up just spinning. I managed to get a pair of mole grips on the bottom of the bolt to get the nut moving, but I cannot get the nut off the bottom of the studding.
The bolt just spins, both ways, almost like it was spot welded to stop it turning but the weld has now broken...
Apart from sawing the bolt above the nut what option is there? What is the problem if I do saw the bolt - will it damage the rad? Can I easily replace the bolt? How is the bolt attached to the rad?
A.
A.
