silicon hoses
    silicon hoses
    does any know if you can use silicon hoses on brake or clutch lines
    thanks dave
    I would think not as they will probably bulge out under the pressure.just my thoughts.
      thanks dave
      That's a definite no Dave, far too soft. Martin.
        thanks, still got to find a new pipe for the clutch
        dave
          dave
          Whats wrong with a new standard pipe Dave?
          Cheers Steve
            Hi Dave,
            most areas have a hydraulic hose specialists. They can usually make you up hydraulic hoses. But as Steve says, what's wrong with a new one from a stag specialist?
              Originally posted by Ian Durrant View Post
              Hi Dave,
              im after the pipe that fit between the clutch reservoir and the master cylinder,
              dave
                There is an SS one available, it looks just like a brake line. Martin.
                  martin
                  i have the stainless one that fits between the clutch master and slave, i need the small 3 inch pipe the holds the clutch reservoir to the master cylinder
                  dave
                  p.s. will petrol pipe be ok to use
                    dave
                    Ah!!! I would have thought fuel line would do the job. You can soak a piece in brake fluid and see if its affected. Its not high pressure so anything that can cope with brake fluid would do.
