Hello all
with the overheating of the engine on the way to the National weekend and the return journey in which I was loosing water in the buckets full I have been trying to annalyse the problem
No water in the oil
No oil in the water
No obvious signs of water loss
looks like it keeps flowing out of the expansion overflow pipe
Removed the thermostat and now the engine only gets to halfway up the gauge but still lossing water
Fitted a new 20psi pressure cap
Checked the pressure of the cooling system and holds 20Ppsi with no loss in pressure over 5 mins
Checked the pressures of each cylinder which was 130psi on each cylinder
BUT
after speaking with Stagmuffin I did the readings the wrong way
So this morning I took out all 8 sparkplugs and took the readings of each cylinder in turn by holding the throttle open and my wife turning the ignition for 5 secs
first reading second reading after two shots of oil added to cylinder
cylinder 1 100psi 110psi
cylinder 2 95psi 110psi
cylinder 3 100psi 115psi
cylinder 4 105psi 125psi
cylinder 5 100psi 130psi
cylinder 6 105psi 125psi
cylinder 7 95psi 105psi
cylinder 8 105psi 125psi
I know the readings are low but wondered if the head gasket has gone would that be where the waters going and explain the low compression readings
The car seams to run well and pulls away fine with no miss fireing
any ideas would be appreciated
rogerk
No water in the oil
No oil in the water
BUT
rogerk
