The Sill is off.
    The Sill is off.
    Finally started sill replacement , took off sill, could not belive what i was looking at rust, holes everywhere, dont feel so bad after looking at other peoples projects here are some photo'sIMG_6165.jpgIMG_6167.jpgIMG_6168.jpgIMG_6169.jpgIMG_6170.jpg
    Good luck Tel, although I reckon it looks like you know what you're doing
    I think many of ours could well be like that, if only we knew I suppose it's only to be expected in a car that's 35 or 40 years old from a time when they were lucky to last 10 !
      That looks like a job that will keep you entertained for more than a little while!
        Thanks Julian i think i will need some luck,thats the good thing about this forum is that you get great information on any thing that you want to do
        Cheers Terry
          I think it will Neil ,after seeing some of the restorations on the forum i was expecting some extra work , but not this much!!!!!!! i hope the other side is not to bad fingers x'ed
          Cheers Terry
            Great pictures and good luck with the work. Once you remove all the rot and see what's left I'm sure there is enough to strengthen and rebuild. Mine had dreaded cover sills and at a glance looked great but what goes on inside is another matter keep up the good work.
            Edd
              Hi Terry, good luck mate, you're already down in my book as a hero, for bringing one of these old girls back to life !
              There are a few on here, and I admire them all. Good luck. Martin.
                Cheers Edd , Martin its going to take longer then i thought ,but i have got over the winter to get stuck in. Mine also had the chrome sill covers and it did not look to bad untill i took them off. I have most parts now just got to get a 3/4 rear wing most suppliers are out of stock.
                many thanks Terry
                  One hole is much the same as another! As Edd says once you get the rot cut out it wont look so bad. The worse thing with yours is that someone has had the chance to do it right before but didnt do it. now its your turn so you can fix their mistakes. Loads of help on here and loads of pictures of Stags in a very similar condition to yours.
                  Good luck and dont forget to keep us up dated with your progress reports
                    Thanks Neil i could not belive it when the sill was off that someone just bodged a couple of repairs, i will post photo's as i go along
                    many thanks Terry
                      Hiya Terry, join my campaign to do away with those sill covers, they can look very attractive, but every time I see them, I think, what's hidden underneath. Martin.
                        i know what you mean Martin i was looking at possibly fixing the sill back on, but easily enough to take it back off to clean underneath without using rivets ,worried about getting metal worm again !!!!!!!!!!!!
