steering rack shims
    steering rack shims
    Guys - I know this has been asked before but does anyone know of suppliers / sources for the inner ball joint steering rack shims used to pack out the inner ball joints (or have they become harder to find than hens teeth) - many thanks
    When I reshimmed mine I bought a set of poly 'cups' which had a backing washer. When fitted they didn't need shimming - if anything they were a little too tight. I can't remember off hand where I bought them - I have had a quick look and can't see them on the major suppliers lists anywhere. I think I bough them from Chris Wittor.
    Also at the same time I took a gamble that the Triumph 2000 shims might fit. (Part No's 130031 and 130032/10). The external diameter is the same and they seem to bear in all the right places, but the hole in the middle is bigger. In the end I didn't have to use them. They fit, but it is up to to whether you deem them to be suitable.
    Chris Witor - Triumph 2000, 2500, 2.5 & Dolomite specialist automotive parts supplier, supplying a wide range of performance and standard spares worldwide - website: www.chriswitor.com - email: chris@chriswitor.com - phone: +44 1749 671404 - fax: +44 1749 671404 - address: Hornsmead, Knowle Lane, Wookey, Wells, Somerset, England BA5 1LD.
      Found it!
      polyurethane bushes, car suspension bushes, uprated car suspension, replacement car suspension bushes, suspension upgrades, polyurethane, bushes, suspension, polyurethane suspension, polyurethane car suspension bushes, suspension bushes, poly, urethane, supplier, distributor, superflex, car, parts, spares, Wells, somerset
      I didn't need any shims with this fitted.
        Originally posted by StagnJag View Post
        Found it!
        Thanks Dave - very useful will order some now
          Hi all, i also had good result s with this product eliminated slight play on inner tie rod but did replace locking tab washer availalble from ld parts .Regards Paul
            Thanks Paul, oddly enough i had already got the tab washers from LD's - its hopefully just these cups now to do the job (fingers crossed)
