So following on from my inaugural post which gives a bit of back ground
I will be picking up my heads at the weekend
Acid cleaned, faces machined, but in pieces, packed away away some 22 years ago and un touched until last month
Will peform inventory and decide what to buy and what to replace.
Will check for corrosion on all ferrous parts
I will check exhaust valve to see if they are the hardened type for unleaded fuel, by then I will also have the engine and comission details
If I need to change exhaust valves, is is imperitive to change the valve guides?
If so, does anyone know where I could hire, borrow and valve guide puller and insertion tool
Or even a simple sketch to make one
I have not been able to find a post specifically on valve guide
I have a good set of buckets, is it imperitive to change the valve springs and plates?
Thanks in advance
Thanks in advance
