Still got major problems with fuel flow. Can't even get from home to my mechanic pal to get my suspension fixed and getting a bit terminally fed up.
i get random good running and then lose power - feels like going down to 4 cylinders. When I stop and then put the ignition back on the fuel pump is thrashing away (and ticking like mad) in the boot. Tonight when I was checking fuel the fuel lines, I find that the pipe from the tank to the pump is firm and under pressure, but the one to the engine is soft. When I pinch the one going to the engine, the fuel pump immediately stops ticking.
I'm out of my depth here. I feel it could be a duff pump, or the wrong one, or a carburettor issue, although they've been stripped already. What is generally felt to be the best pump on the Stag ?
Someone tell me it would be impossible for the engine to get any petrol if the pump was running backwards.....
Any thoughts from you long suffering experts ?
