Rear wheel bearings
    Rear wheel bearings
    I have a spare pair of drive shafts that I need to get the rear wheel bearings changed. Anyone in the surrey area have the necessary puller to get them apart, and spanners to adjust the bearings up, and dial gauge to do it properly....
    .... actually can anyone do this for me in exchange for beer tokens or tree pruning!
    Cheers...Al
    I think Ian Milothedog is the man you are looking for.
      Going down to Taunton today so decided to whip the driveshaft out and see Uf I could nip the bearing up a bit. Seems to have worked, and a lot of play been removed.
      There is slight vertical play in the splines when the wheel is off the ground, is this to be expected?
      Cheers....Al
        Cheers....Al
        Hi Al,
        Just read your post. If your stuck get in touch, I still have all the specialist tools but limited access to the press now that I'm a man of leisure
