Having found some time to get back to working on the Stag that's been lurking in my garage (since 2002 according to the tax disc), last week I tried welding the centre top-hat section to the floor pan (the one that runs across the car just in front of the seat runners). Of course it should be spot welded in place, but as I have a Mig welder I tried making puddle welds, i.e. holes drilled in the floor pan above the tophat section flanges and then welded through the holes.
As you can guess if it had worked well I wouldn't be writing this
. All I seemed to be able to do was fill up the hole and make a joint that came apart as soon as I threatened it with an old screwdriver. I based the size of the holes I drilled on the punch that is on my joddling (joggling?) tool (about 4 or 5 mm) and had the welding current set for 1.5mm material using .6mm wire. Can anyone who's done this successfully enlighten me where I'm going wrong? From what I've read it shouldn't really be necessary to make a large hole (say 10mm) and weld around the inside of that, though that is what I may have to resort to.
Many thanks, John.
Many thanks, John.
