Plenty of threads on this already Adrian - just search waterless http://www.stag.org.uk/forum/showthr...ight=waterless. The consensus seems to be that if you look after your cooling system it doesn't need this (very) expensive stuff.
Paul
Hi Ade, a couple of folk were having this stuff installed at the nationals, first, there's an expensive flush, then the Evans Waterless was put in, your talking about a couple of hundred quid, if you get a bad leak or lose a hose it all goes down the drain, and I believe you can't replace it with water. Huge no no as far as I'm concerned, somebody also pointed out that it makes the Stag engine run hotter. Martin.
