Hi, any feedback....coments or suggestions on best sparkplugs
Spark plug choice standard/iridiums?
Originally posted by Staggard View PostI used iridium plugs in my old Bonniville and in my old Hyundi 1999 nothing but aggro missing ect. So I binned them and replaced them with NGK (Hyundi) Champions (Bonniville) and no problems now. I don't think they work so well on older ignition systems, never tried them in the Stag tho. Graham
Blimey - you're doing well, the last time I looked they were £20 each
Martin.
Guest
I use Champion N11YC and have had no problems at all.Off course our cars in NZ are used all year round.I also use 96/98 octane fuel.
Anthony
Iridium plugs the last time I checked for most cars were around £20-30 for 4 plugs (NGK Brand), which is similar to what OEM platinums cost on most family cars
In a Stag I reckon they are a bit of a waste with the mileage most people cover (and for what they cost (you would probably be looking at around £60 for 8 plugs!)).
i have used NGK BP5ES with no issues although I may switch to Champions next time just because
If anyone wishes to obtain a cheap set of BP5ESs let me know
copy and pasted . thought this was good
How would you like to be shut in a chamber with temperatures of up to 3000°C, splashed with petrol and given a 30,000 volt electric shock 25 times a second, and be subjected to pressures 50 times greater than normal atmosphere? No? - well that’s what your spark plugs are subjected to! So if you want peak performance from your engine, make sure you fit suitable plugs.
Oh I dunno Alan - doesn't sound too bad to me
M.
