Plusgas
    Plusgas
    Anyone know where to get Plusgas from?
    I've found it online but with delivery works out at £12-£14 a can!:shock:
    Rgds......Al
    Arbman101 - It's actually more readily available than you think. It can be found on practically any garage forecourt and, according to where you live costs about £1.30 a litre. You'll need to take your own container as well.It wont be sold as Plusgas though. You'll need to look for a pump dispensing a product called DIESEL.
    J
      Rgds......Al
      Hi Al, i got my last can from what used to be Frimley Motors (can't remember its new name)in Frimley High street - seem to recall it was £3/4 , Camberley Autofactors on Hawley Road will probably sell it to .
      cheers.......Andy
        seen in trago mills £2.75 spray cans
          What is PlusGas?
          Sounds really good, must get some
            What is PlusGas?
            A bit like WD-40, only it works. I've not seen is as an aerosole only a tin of liquid, but you might be able to get it in that form if you look hard enough.
            [edit]
            Apparently you can...
              the WD in wd40 means Water displacer and it does its best at that the other things are just by-product atributes, i am with bigj diesel is best/cheapest option
                FIVE PRODUCTS IN ONE - THE 5 FUNCTIONS
                • CLEANS: WD-40 gets under dirt, marks and grease making it easy to wipe away. It also dissolves adhesives, allowing easy removal of labels, tape, and stickers
                  PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements
                  LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts
                  PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts
                  DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits. Turn the power off before you spray
                  If anyone needs any, I have arranged delivery by supply vessel of 600,000 litres of diesel over the past 5 days. Only two problems:
                  1. It is 'red' diesel
                  2. You will have to travel 90 miles NE of the Shetlands to fetch it
                  Pity I can't bring some home on Friday, as the misses is finding it difficult to get some at home with the filling stations running dry
                    I wouldnt want the tax bill for that lot!
                      off shore and red i bet the gov pays Dave to take it!!
                        AND ELVIS ATE MY HAMSTER :Xnot saying its not good for somethings but there are far better things for undoing tight things...heat is as as good as any, its first job was as a water disperser on ignitions ect, its also good on cold lorry engines as damp start, but don't quote me....it was only a little fire
                          .... as the misses is finding it difficult to get some at home...
                          How long do you stay on the rig Dave?:P
                            Home Friday. Nudge, Nudge, Wink, Wink!
