Are mk1 and mk2 cubby panels the same?
    Hello all, went to fit two long since purchased cubby panels to my mk1 but they don't seem to want to fit. The cut outs (for what i presume to be the seat belt fixings) are nowhere near in line, are the mk1 & mk2 cubbys different please?
    Gord
    No, they're not the same. At the very least, the apertures are a different size.
      As Julian said, the pockets are a different size, larger on the mk1. The mk2 has smaller pockets to accomodate the seat belt cut outs.
      The seat belt mounts are in a different position on the earlier cars so if you are doing what I did and fitting mk2 panels to a mk1 so you can use the belt apertures in the panels you will probably find you need to move the seat belt mount position.
      Pete
        Righto fellas you've confirmed what i suspected - thanks for the responses
        Gord
