Hi, I have recently purchased my 1st Stag, a 1977 MK2 Tahiti Blue MOD with approx 124,000 miles on the clock.
I'm sure this will be the first of many questions. I’ve noticed a pipe (vacuum?) coming from the front of the inlet manifold has been blanked off. I suspect it should go to the thermic sensor on the air cleaner box. The pipe to the thermic valve on the top of air cleaner box is also missing, so I assume that should come from the front connection on the thermic sensor. Please could someone confirm my assumptions are correct or explain how the pipes for the thermic sensor and valve should be connected?
Many Thanks
Chris
Many Thanks
Chris
