"Mystery water puddle"
    Found a mystery puddle under the front of the car, level with the front of the cross member, did not look like anti frezze or taste like it, no leaks on water system (no water loss), (water being sucked back into system when cold).
    Would it be from the breather that comes from the carbs down the timing cover?
    102.jpg103.jpgwhat do you think boys
    Cheers again in advance
    [ATTACH=CONFIG]18599[/ATTACH][ATTACH=CONFIG]18600[/ATTACH]what do you think boys
    Only if it's petrol, that's an overflow pipe, in case the float chambers flood, you need to identify the fluid eg oil,water,tqf,brake fluid,windscreen washer fluid, petrol. you don't own a cat do you ?? Graham
      the front pipe from carbs is petrol not water.
      please don't taste antifreeze don't think its good for you
      maybe its the washer bottle or condensation, should not worry too much, mop it up and see if it appears again
      alan
        I have a similar leak - must be something affecting yellow Suffolk Stags!!
          must have been posting answers at the same time!!!!!!!!
          alan
            Not petrol, or anti-frezze as does not taste sweet, hope not a cat as been licking it, fingers i mean, could it condensation from oil cooler?.
            M&M
              Fitted with aircon?
                No sorry
                  alan
                  OH dear I've been on the bluecol when the red wine has run out (ok ok I thought it was funny)
                    M&M
                    If that's from a cat, I doubt that it's spit A word to the wise, with reference to Alan's comment, DON'T taste leaks ! ! The fluids all smell very different so no need, I do hope it's not cat piss !
                      M&M
                      Never heard of that ! proberly best to do what alan said mop up and let us know if it happen's again.
                        Did you operate windscreen washer before you put Stag to bed?
                        Water could have run down wing channels to fall front of bonnet leading edge.
                          No did not use washers, will see if it does it again, strange though?, cheers
                            No puddle yet
                              Definately don't get hooked on the antifreeze. We see enough cats and dogs through work that like that sweet taste and lick it up from the driveway or wherever, and end up in kidney failure. Awful to watch.
                              Tanya
                              Tanya: Brit in Canada
                              71 Fed Stag, TV8, ZF 4spd auto, EWP and crossed fingers
