While cleaning the inside of the hard top, I found two C shaped burn marks, just above the vents in the C pillars. I'm guessing there are two high resistance connections to the HRW. Does anyone know if there's access to replace them without stripping the headlining ?  Martin
Hard top electrics.
 Hi Martin,
 When I had mine stripped down, there was just a simple wire from the B pillar connector to the outlet at the C pillar.
 As far as I remember, if you were to unscrew the C pillar vent that should give you access ok.
 At worst, the headlining is only glued to the C pillar but I fear, if it's old, you might damage it if you tried to unpeel it.
 Alternatively, if the hardtop is off the car, I'm sure you could feed a new wire through with a bent coathanger.
 I've got what's left of my old hardtop outside if you want me to look at anything on it.
 Hi Mart,
 when i refurbed my top, i'm sure there are 2 clips somewhere there that hold the wire in place, perhaps it could be a mark from the clips and not nessasarly a burn mark, just a thought, i have some spare wire i think if you need it, and as Julian has said, it is just one lenth of wire
 hope this helps mate
 alan
 Hi Martin,
 Here's a few pics of the wreck of my hardtop to give you some idea of what's lurking under the headlining. I know it hasn't got a B pillar anymore - that got sent to someone on the forum a year or two ago !
 Bath's a bit of a stretch, as much as we love it.   Martin.
