I've taken some time of work so I can get on with some jobs on the Stag one of them is to give it a service and general check over, since I've only had it 4 months so I checked the ignition timing with a timing light (Im assuming that the pick up sensor clamps on number 2 lead) and it's firing at about 18-20 degrees BTDC and in the manual it states 12 degrees is there any reason the previous owner would have set the timing like this or could it have just moved, it seems to run fine no loss of power no pinking, I run it on standard unleaded with additive (valvemaster plus) as the valves have not been redone. Any thoughts or suggestions would be appreciate.
Many thanks
Many thanks
Martin.
