Heater.
    Heater.
    I took my Stag heater apart a while back,inevitably I can't remember what goes where......Do any of you fine chaps know where I can locate a drawing showing an exploded view??
    Thanks Andrew.
    Not a fine chap , but here are some photos of the innards and the untampered version. Couldn't find a diagram either. The heater matrix is out in the 'exploded ' view.
    Tanya
    Tanya: Brit in Canada
      In his 'Bavarian Stag' thread, Drew had loads of heater pics when he completely dismantled his. Should be worth a search.
      Only trouble is that everything Drew does is so damned good that it makes me jealous
        That third photograph is superb, showing the cables, rods and heater valve as it does, I may print and keep !
        All of those would be worth putting in the tech section. Martin,
          Whilst at the nec show I picked up a rimmers catalogue. It has a virtual breakdown of nearly every part of the car together with a part reference number. I will still price compare parts over the different suppliers but I have to say rimmers book is a excellent help to rebuild showing every nut bolt and washer. I'm sure they would post a copy if asked.
          Edd
            All of my heater pics are here:
            http://s221.photobucket.com/albums/d...cpZZ1QQtppZZ24
            Additionally, my Heater Disassembly Notes (might help)
            Stag Heater Disassembly
            1Remove the cable of the LH vertical slide lever (OFF - FRESH)
            2 x green cable clips
            1 x P-Clip fixed with Philips screw
            1 x cable attachment clevis pin.
            2Remove the cable of the RH vertical slide lever (OFF - SCREEN - CAR)
            3Remove the cable of the Top horizontal slide lever (COLD - HOT)
            4Remove the slide lever assembly
            pull off foam block
            remove 2 Philips screws which have their heads under the foam block
            5Remove the square central air outlet duct
            4 x tiny Philips screws.
            6Remove the Air Intake Panel
            8 x tiny Philips screws, then the panel can be slid out and removed
            6. Side plates
            Remove the star washers (3 on LH side plate, 1 on RH side plate) retaining the flap operating shafts
            Remove the rubber bung on the LH side plate
            7Remove LH Side plate
            2 x mini Philips screws on the plate surface
            7 x mini Philips screws on the circumference flange (1 is well hidden under an air flap hinge shaft)
            2 x normal Philips screws on the straight sections of the flange
            Pull off sideplate noting that there is body sealer and sticky tape which have to be overcome.
            8Remove RH Side plate
            Noting the position of the levers, remove the cranks from the end of the flap spindle shafts
            1 x mini Philips screw on the plate surface
            Pull off sideplate noting that there is body sealer and sticky tape which have to be overcome. Manoeuvre sideplate past the heater matrix pipes.
            9Heater Matrix and air regulation flaps.
            The heater matrix can now be carefully removed..
            The air regulation flaps can be removed. Note their position and orientation.
            10Motor assembly
            Remove the 6 mini Philips screws (2 per side) and remove the motor assembly
            11Motor cowling
            Remove the 18 mini Philips screws securing the cowling to the motor end plates
            (4 rows of 4 screws, one row of 2 screws)
            12Motor vanes
            Remove the plastic ventilator vane wheels from the motor spindles. Note the position of the vane wheels and their direction of rotation. It should be possible by twisting one vane wheel against the other to gradually withdraw it from the spindle. Then grip the spindle with a suitable wrench and remove the second vane wheel by twisting and withdrawing. It should not be necessary to release the metal clips which grip the spindle centre hub.
            The motor end plates now are free to be removed.
            If the plates are going to be refurbished, then it is now time to drill out the two rivets holding the resistor to one of the end plates.
              Typical of Drew - scant attention to detail
              Only kidding, of course. It's just because I'm jealous
                Wish my hubby had made detailed notes like that! He was on heater duty and complained the whole way through, and then lost two cable grips which had to be ordered! I did replace the worn and brittle bits of foam and had the blower unit checked over by a specialist while the assemby was out. I still have the old matrix, at first I thought it was rusted out, but when hubby removed it, we found it was made of copper! Seemed a shame to put the new boring steel one in!!
                Tanya
                  Are you sure it's made of Steel and not Aluminum or other Alloy
                    Probably aluminium, its grey anyway....... (notice I spell aluminium correctly....and grey!!)
                    T
                      T
                      Must be my "Spill Chucker" on the laptop not working properly
                      I asked because I wondered if someone was producing an alternative modern replacement. (like the throw away ones cars have now)
                        LOL
                        I got my replacement from the usual R supplier. Much lighter in weight compared to the old one.
                        Tanya
                          I'm guessing the laver and cable in photo 4 with the tape is the fresh air vent? Mine won't close so it must be stuck somewhere the photo will help me locate the problem. Cheers
                            Your speeling's no beter than moin
                              I most humbly thank you all for your help in his matter, it will take a lot of the guess work out of the reassembly.
                              Many THANKS, Andrew.
