Hope you can help!!! On the way home tonight all running fine and pushed in choke, when came to the lights and stopped the revs were still quite high but the choke was pushed in all the way, around 1500 but it has been difficult to get the choke completely off the last couple of times. So I thought to pull the choke out and then push back in - that was not the best idea!! the revs went up to 3K and stayed there even when the choke was pushed in all the way. I only had a further 5 or so miles to go so just got her home. Interesting when going slowly (or trying to go slowly) as hardly needed any throttle in fact could have done with out it!!
When I got home and turned her off she must have run on for at least 5 seconds - thinking that was the excess petrol.
I thought that it would be that the choke was stuck on but when the bonnet was put up it seems not checked that both sides were in the "off" position - I started her up again and the revs were straight up to 3k again.
After letting the car cool down (and having tea) have been back out just to double check that the choke wasn't stuck on and it is definitely off. Started the car again and engine fairly cold started with no choke and sat at 2k. Also noted - may not be linked but the top hose from the radiator to the water pump was sucked almost flat.
Any ideas?
Any ideas?
