oil filler cap
    oil filler cap
    Hi guys
    Just started engine today after having heads skimmed and welded, all fine apart from water in the vee lol whats new, but when i take the oil filler cap off with the engine running the revs drop a little, just drop not stop, is this normal
    Sounds ok to me. Mine only drops 100 rpm or so and, as far as I can tell, my breather system is all ok.
    Julian.
    Ps Don't let the paranoia get to you
      Hi
      Thank god for that mine drops about that amount cheers
        When the revs drop that's a good sign. It's happens because additional air is sucked into the engine via the breather system; this weakens the mixture which in turn causes revs to drop. The dipstick is also a place where air can get sucked in if the felt washer is missing.
          Thanks Chris
          Every day is a school day
