Tried to make the most of the sunny weather by fitting the new weber conversion kit. Be fair pretty straightforward to fit, bit fiddly getting the securing nuts tight ended up using a very skinny spanner which did the job okay. Only real issue was when i moved one of the manifold bolts to secure the new throttle cable support it stripped the thread, its gone back but wont tighten up to well, im going to have to sort that out when i get a bit more time and dry weather.
Car started up pretty much straight away and with a bit of adjustment is ticking over better that it ever has. It seems to pick up smoothly and rev freely too. It coughed back through the air filter a couple of times during the adjustment process but seems good now.
I wanted to take it for a spin but weather changed before id finished boxing it all up. It idles really smooth and sounds good too!
Took the opportunity to change the plastic inline filter which was full of crud.
So far so good, cant wait to take it for a little spin to try it out on the road!
