How to convert a Stag to triumph 2500
    Hi
    Having just converted a Stag (auto) to 2500 manual o/d, Im extremely pleased with the results and thought I'd put down some of the detail in case anyone else wants do this.
    I was searching the internet for information trying to make sure I bought the right parts, something like this would have helped me so hopefully this will aid anyone doing the same thing.
    You need ....
    1 x Stag with (knackered engine)
    1 x triumph 2500 engine (with saloon type front plate for engine mounts)
    1 x 2500 manual o/d gearbox.
    Note : The stag manual box and the 2500 engine have the same bellhousing drillings, but the input shaft on the Stag box is longer and thicker so it won't fit intot the 2500 clutch/flywheel. Also I gather tyhe Stag 1st gear is a higher ratio than 2500 box. If you changed the input shaft, it looked to me as though the stag box would fit, buit really you may just as well find a 2500 gearbox.
    2500 front crossmember (with engine mounts), and 2500 anti roll bar clamp assembly. At first it might look like the ARB might not fit properly, but it does you just have to push it about a bit.
    I gather you can use the Stag engine mounts in the bay and make up vitesse-style mountings for the engine, but that was a bit beyond my facilities. If you do this, you don't need the new front crossmember.
    2500 PAS pulley. The pump itself is the same as the Stag one, but the pulley is different. The stag one would interfere with the radiator hoses.
    You can keep the Stag radiator but you have to make sure it's as far forward as it will go. Mine's pretty close to the engine crankshaft bolt. There's only just enough room to get a fan belt past it ! However it's an aftermarket aluminium one, so might be a bit deeper than standard anyway.
    Ideally, it would be better to hack the body about a bit and move the radiator forward a few inches, but I haven't done that.
    You need some new radiator hoses: I had to make one up out of 2500 hose and the metal tube the stag uses (had to cut that up a bit)
    Watch out for the rad filler nut at the passenger side end : it pokes up a bit and if you re-locate the radiator forwards, it could foul on the bonnet.
    2500 manual gearbox crossmember : This will fit directly onto the Stag body, but you need elongated bolts for the mounting and the tubing spacers they sit in to keep it all tight.
    The Stag Auto (maybe manual?) transmission tunnel fouls against the cluitch actuation arm on the side of the 2500 gearbox, so you have to move this somehow. I used a BIG HAMMER. It just needs pushing over an inch or so. I discovered this after the gearbox was already in, so I just levered the inside of the trans tunnel against the gearbox side and made a bit more room.
    2500 exhaust: (Manual?) But you have to shorten it by about 5". Originally I cut it just after the first silencer box (about the middle of the propshaft) and put a straight tube connector to mate the pices up. It worked but there's a lot of tension in the system that way so I put a chicane in which shifts the centre section over by about 2 inches (made one up- 48mm inner diameter tube worked). That seemed a lot more 'comfortable'. The Stag rear mounting doens't align the ame so you have to come up with someting innovative.
    Standard Stag propshaft : I used a rimmer bros one with CV joints. Brilliantly smooth, hopefully 'fit and forget'. This is important info as I had to the the plunge and buy one to see if it'll fit.
    The Stag gearbox rear flange is larger than the 2500 one by a miniscule amount so to fit the stag propshaft you need a Stag flange. The rear one on the diff is the same though, of course.
    The nut whcih holds the flange on appears to be 28mm or 1 1/8". A socketthat size is quite hard to find ! But you can order them online.
    Undoing the nut on te flange can be f. difficult. I only realised the different size one the gearbox was on, so .. tricky.
    I virtually hung on the socket and handle but it wouldn't budge. Eventually I did it by putting a socket on it, and a long extender on the handle so it lodges against the chassis. Then put the gearbox in REVERSE and try to start the engine. Ping! the nut gave way. Good nut. Nice nut. Lovely nylock nut. Have some copperslip.
    The air filter on the 2500 would normally go where the battery is on the Stag, so in theory you should move the battery to the passenger side inner wing (as per the saloon). I didni't do this : I left the battery in its box on the driver's side, and fitted a tubular air filter bought from Halfords. I don't have te code on me but they do tubumar ones which fit straight onto the J part of the air filter box on the 2500. It was a bit tight so I made a curved tube up to hold it in a better place, just above the PAS pump.
    This makes things a bit leant towards the driver's side : PAS pump, carbs, exhaust, battery, air filter all reside there. Seems ok though ! The only thing you could really move is the Battery which wouldn't make much of a difference really. You have to move the screen washer bottle to the pasenger side, but that becomes obvious pretty quickly.
    I converted from Auto, so had to take care of clutch cables etc,
    First I needed a manual pedal box with clutch pedal : That's not too hard to change. You could, in theory, just change the brake pedal (to big on auto) and add a clutch pedal but it's much easier to xchange the whole box.
    I had an old Stag clutch master cylinder knocking about so I used that. If you do this, be sure to buy the 1" (larger) bore clutch slave cylinder for the 2500. I bought the 1 7/8" smaller one by mistake and the result was too much throw in the clutch, giving some very odd noises and the clutch getting stuck disengaged (until I bopped it back with a hammer). I'm aware it could have popped off the clutch actuation fork.
    You need the 2500 clutch hydraulic cable too, of course.
    Inexplicably, the thrust arm from the slave cylinder to the clutch was too short by about 2 cm, meaning when you put the clutch full down the slave cylinder spat all its innards and fluid out. I put a spacer in the bar (a small, long reach socket which I never use) and that seems to have dealt with it.
    The Speedo cable screwed straight on to the gearbox I had bought, but the spindle which it inserts into was missing on the box so I used one out of a Stag manual box I had knocking about.
    It's a bit tight but it fits. More on this in a moment. though.
    The electrics are quite easy to sort, but the starter motor is on the opposite side on the 2500 manual box to the stag auto. The result is you end up with a lot of 'spare' power cable from the battery to the starter. I just looped it up the inner wing and wrapped it in cable protector. I'm glad I did this because the engineer's report fella pointed out it was wearing itselfr out. After only a few miles of test driving, it had worn its way through the paint on the inner wing ! as all this is right below the carbs, if it had worn such that the cable connected to the wing, a fire would seem very possible.
    The auto box has an inhibitor which stops you starting it when it's not in "park". There's quite a substantial plug to service the auto box its electrics, and it's part of that. I shorted the starter inhibitor wires across by putting a thick copper wire into the relevant plug holes. I haven't yet dealt with the reverse lamp but It think this is catered for in that plug too.
    The issues I now have are :
    * Speedo reads low by quite a lot. 30mph on speedo = about 40 in reality. I think this may be because of the spindle thingy I used in the gearbox where the speedo cable attaches is the wrong type, and/or maybe the speedo is tired. I need to research that a bit.
    * Haven't wired in reverse lamps yet. I forgot them. The switch is on top of the manual gearbox so it's a bit of a faff. One day ..
    * The rev counter is still for the v8 but I now have a 6-pot so it reads two-thirds the right amount. A straight replacement with a 2500 rev counter will fix this.
    * Engine sits a touch high in the bay, and the radiator pipe rubs a bit on the bonnet padding. It doesn't mis-shape the bonnet though so I'll let it just bed in.
    * The smiling is starting to make my face ache :-D
    Update :
    After 3 months of driving about, I've discovered that I've accidentally bought an excellent engine. Nice and smooth, and burns no oil.
    The current setup isn't fast on accelearation (down 30 bhp from standard v8 140bhp?) but it cruises easily at 70 or 80 and is quick enough to be fun. I was also astonished to find that on a run it did 31mpg, before I'd managed a detailed tune-up (timing, carbs). I'm tempted not to touch anything!
    One star of the show is the exhaust : I've used a standard bore (late- 1 7/8") 2500 exhaust with 2 x mid boxes and tail box. It's virtually silent.
    The smiling is really hurts now..
    Thank you for posting this detailed report, what a lot needs doing!
    Wouldn't it have been easier to mend the TV8?
    Glad you are still smiling though.
    John.
      Hi John,
      It's a lot of work, but most of it just bolts together so long as you have the right parts, so you can move through it quite quickly.
      My triumph V8 blew one head gasket. Undoing the studs revealed one siezed.. it took me months to get it out, replace the Head gasket, and put it all back together (using a hacksaw blade and a special brand of swearing I invented for the job). A few months later the other side blew. I now realise this was always going to be the case, as whatever caused the 1st will affect the other side too. However this time I have two siezed head studs, and they're in a place where I can't drill them out with the engine in the car. And they're properly stuck. No movement at all. Add to that the blue smoke, damaged valve and timing chain replacement, plus I wanted a manual O/D not Auto.. I know my limits!
      It had to come out anyway ... and I was reluctant to put it back in so it could blow again because .....
      I want to drive the car to Italy over the alps this summer with my lovely fiance. I didn't have confidence that the engine (maybe it's just that one..) would handle the heat. I think the straight 6 will handle it no problem :-)
        I guess some people feel that the TV8 is doomed from the off, in addition to the conversion costing less than what most specialists would charge for a pair of HGs to be changed.
        Saying that, it is good to see a detailed report of how things should be tackled if one decides to undertake the 6 pot conversion.
          My feeling is that it's a shame not to keep the V8 because when it was running well, it was magnificent. Revvy, smooth, powerful, quiet- generally brilliant. Saying that, the straight 6 is no bag of nails :-)
          The conversion is mainly a reliability thing really, and I'm realistic about that :
          The Triumph's sturdiness multiplied by my ability to maintain it = a very small number.
          Anyone need a TV8 engine ?
            Well done, Just going through the same procedures, lost faith in the TV8 after Head gasket failure, and one head won't shift even with an angle grinder, what did you do about the alternator cabling? as its also on the the other side from the Stag v8.
            Phil
              Hi Phil,
              Aha, hopefully this has been useful to you already !
              I cut the alternator cable about 3" from the plug end, and put in an extension using 17 amp connection blocks (the type where you put the cable in a kind of tube then scew down a bolt onto it - not sure what they're called), and the heaviest wire I could find, which in fact was lad-style audio wire from Halfords. Seems to have worked just fine.
              So you end up with the same plug fitting, just on a longer cable. Incidentally I had to get an engineer's report for mine and the fella was quite picky, which is good- one thing he picked up on was that all cables, electric/hydraulic etc, have to not chaff on each other and be held securely. Judicious use of cable ties & cable protectors (B&Q) secured this.
              Have to say it's great to be talking to people who in a similar situation. How's yours going ?
                Nice work !!!
                The engine that the Stag was originally designed to have from day one, with the V8 coming along a few years later following further development (if only) !
                Story is that the US was seen a insisting on the V8, so as it was intended to be a major market the V8 was perhaps rushed into service to meet that perceived need.
                One question that always puzzles me is why Triumph never reverted to the 2500 straight six, even in twin carb (ie. not PI) form when the V8 began getting its poor reputation ?
                I've not heard a Stag with a 2500 but always sounds nice n throaty in the TR6 and saloon, so would still suit Stag IMO but the V8 just sounds sooo sweet !
                  Mine sounds just like the big saloons- v quiet but with a slight 6 pot rumble to it. I had a 2500 stag before (sadly written off) which had a Chris Witor sports exhaust. It has one less silencer box & bigger bore. That sounded nice, although was a bit loud & raspy for my liking.
                  It would have been so great if they'd released a "baby stag" with the 2500. No idea why they didn't, seems like a no-brainer (albeit with 20-20 hindsight haha).
                    Doug,you could always try the Tony Hart straight through SS exhaust if you did want more sporty noise £235 fleabay item number 370706111480
                    Paul
                      i went the other way, when i bought mine 23 years ago it had the triumph 2500 engine in,funny enough it over heated didn't look to find out why,looked for a stag v8 engine then found out the import shaft on the gear box was different so then had to find a stag manual gear box
                      dave
                        As I understand it (from a recently released Video ...... if my memory has not failed me) The Six was considered underpowered with all the strengthening steel put in place once the modification of the Saloon shell into the convertible Stag had taken place. A 2500 V8 was designed but subsequently increased to 3l V8 once it became clear that Rover were not going to make their 3500 V8 available. Triumphs Unique twin overhead cam should (and could have been given the proper funding for further development) have been a major selling point.
                        Poor quality control both from their suppliers and from Triumph themselves let the car and the public (in my opinion) down. Lack of sales clearly reduced the amount of desire management had for approving money for the required development.
                        I seem to remember seeing most of this on that video....
                          There was an article in the April issue of Classics Monthly earlier this year which directly compared the 3 engines - TV8, RV8 and 2500 six cylinder. Roger P's was the TV8, the six was owned by Steve Matthews and mine was the RV8. Thr six cylinder sounded lovely, although I prefer the sound of the RV8 (I would, wouldn't I!)
                            Clearly the exhaust note swayed them too much! Either that, or the need to always tinker with things was always present .
                            I have heard a Stag with a 2.5 PI engine. It did fit the car better than I thought TBH. His exhaust system was rather cheeky mind you! (Read basically half of a Stag V8 system being employed.
                              I read that magazine article re the 3 engines in a Stag. I've actually had all three: The first Stag I bought had a Rover v8, & SD1 5 speed box. I still have the engine & box actually (looking to sell)!
                              It went like the clappers - probably the fastest car i've owned, but burnt fuel for fun. The problem was the gearing : the 5 speed box isn't really tall enough (even with 3.45:1 diff) for relaxed motorway cruising. If I'd got a taller diff, it would have been lovely apart from the other issue which was that it cooked everything! all the wires, the trasmission tunnel got so hot on a run. I guess in hindsight it was probably because a lashed-up exhaust. The wiring in the engine bay went hard and broke as soon as you tried to move it, and your left leg gotcooked against the transmission tunnel .. I wasn't a fan in the end.
                              Anyone else have that problem ? I concluded the Rover v8 was just a tad too big for the engine bay.
                              The first 2500 Stag I owned (long story) was actually bloody awful, but it was badly tuned and gutless. I sorted that out and it went quite well, in a "I see the potential" kind of way. the engine was a bit tired though.
                              Finally I ended up buying a really nice standard 3.0L stag. It was fabulous while it ran, but the head gasket issues saw the engine off.
                              I got very lucky buying a good 2500 and various bits, and made up my current car. It's far better than my first 2500, has a similar refinement to the TV8 but obviously less power (and quieter).
                              I make it sound like I have 3 stags.. I don't. Very sadly one was written off in a prang. The other, the first 2500 one was horrifically bodged by the previous owner's 'restoration' (that in itself is worth another post ! Who would repair inner sills by sleeving them inside with girder, then NOT weld the girder to the car?). I scrapped it as it was a death trap.
                              Very happy with current 2500 stag- it's the car I always wanted :-)
