I've converted the dash lights to LEDS following a path travelled before and a parts list that Martin supplied. All seems to work well with the dash out. When I apply 12 volts to the red and pink wire that fed power to the rheostat. Lights come on. I've removed the rheostat and wired the red/pink wire to the red/white wires that feed the gauge lights. I assume that makes sense?
When installed, the 10amp fuse (fuse 7-8 or fourth one from the end) blows each time I turn on the side lights. I unplugged the multi pin connector to the instrument cluster and the problem goes away.
My multimeter indicates no continuity between red/pink and black at the multi pin connector serving the dash lights. Is that a quirk of the LEDs?
While writing this I've realized that there is a back feed from the dash to feed the fag lighter illumination. It occurs to me That I may have got this screwed up.
Any other suggestions???
Nick
Nick
