Hi,
One more question and then I'll be quiet for a while - promise. Back to work tomorrow and looking busy.
Still trying to figure out why my Stag doesn't have dipped lights, but has main only. Replaced worn out steering column switch. The fusebox wiring looked like it didn't follow the wiring diagram, but that's now sorted with V-mad's new fusebox.
The dash is now out so gives me a chance to look at the wiring again. Looks like the loom to the engine bay on the left has been cut through and resoldered together. I have only checked the redone connections, they seem good and solid, and rewrapped the insulation tape, but it does look a bit Heath Robinson.
Then it looks like there are wires that come from the master light switch straight to the engine bay loom and they must be bypassing the fusebox? It looks like one wire serves both left and right hand dipped beams. There are also loose ends, not taped up.
Incidently, the right rear marker light wiring was spliced into the right stop light even though the marker light wire is right there but taped up. The right stop bulb doesn't work some of the time, although the marker light worked. Anyway, I put all that back to original.
What bothers me, is I am no expert, following somebody who is expert enough to know shortcuts.
My plan is to rejoin all the cut wires back to original. Does my suspicion of bypassing fuses seem valid?
I wonder what mystery problem made them do that?
What i think is happening, new wires in black:
Tapped in wires to loom going to steering column
Cut and rejoined loom with one wire connected to two. Left is engine bay, right is to loom behind dash
Thanks for all the help from the forum, it gives me the courage to keep going on my own
Tanya
Tanya
