offset
    offset
    just bought some new rubber and ally for the stag ( early mk1 ) and found out an interesting fact or did i ,who knows about the stag wheel offsets apparently im told that a mk 2 is 15mm but an early mk1 is 20mm the wheels i will be using require 5mm spacers but will fit straight on to a mk 2 puzzled thought they were the same
    steve
    steve
    I wonder if that is just the difference between a Steel rim and an Alloy rim Steve !
      dont know ian good shout but would like to find out,need an anorak
        There was somthing on here recently about using spacers on a Mk1. I've got a hoodie you can have will that do
          and you know where you can stick your hoodie so hows the box since you sorted it been out on any good runs..............
            The box is brilliant totally different car I am in top at 45 km's preforms stright from cold and it don't dump oil all over my drive, which makes Sonia a very happy bunny been using the car but it sounds a bit like a wasp f**ting in a tin can (manifold) But I know a very nice chap who has solved that problem for me Graham
              steve
              if your using 5mm spacers will the wheel studs still be long enough to come through the wheel,and if your pushing the wheel out will it then rub on the arches ?
                Have to wait and see when I get them Dave should be Friday fit sat I hope
                  Yes, gottem.
                    Originally posted by martin View Post
                    Yes, gottem.
                    please expand on this oh wise one
                    steve
                      steve
                      My Minilites centres don't clear the front hubs so I added 5mm spacers, now they do, 5mm is very little to lose from the studs and the nuts grip perfectly. Will that do grasshopper ?
                        steve
                        You have better sort out your offset before you set off..........................
                        Adrian
                        4x4 Manual OD Stag
                          Adrian
                          If your car wasn't the Holy Grail you wouldn't 'arf get some stick for that one !
                          PS, can you make it to Stoneleigh ?
                            Got to catch me first!
                            Can I make it to Stoneleigh?
                            Don't see too much reason why not at the moment - but I do spend a lot of time out of the country at the moment.................
                            4x4 Manual OD Stag
                              Hello all,
                              om my Stag I use alloy wheels from Appliance Industries (USA). They were made in the 1970s with that typical "Wolfrace Mag Slot" design.
                              The technical data are as follows: Appliance Industries, Harbour City, California (« Wolfrace »-Design) 6x14, ET +19, LK: 4x114,3 mm.
                              Best wishes,
                              Dieter.
