Fixing screws, bolts etc Best place to buy..
    I'm fed up with hunting around for the right screw for this and correct bolt for that.It takes up so much time as I'm sure we all know.
    I want to build up a new stock of fasteners in bulk.
    Where is the best place to buy in quantity..
    Ive looked at A series spares for the bolts,its mainly the screws..
    When you say Screws, do you mean the bright trim self tapers. If that's the case your better off just buying what you need, i.e. W/screen capping, door tread plates etc.
    Got all mine from Peter at LD's. some of them can be expensive for what they are and have limited applications so there's not a lot of point in having loads of them lying around.
      Do a search on ebay. You can get pretty much all the stuff you need but it takes time searching through "shop" listings.
        try namrick pretty good for general nuts ,bolts etc
        alan
          Sorry Ian I should have said I have a few Stags and want to build up a stock.If I can buy in bulk somewhere it would hopefully make it cheaper.
          Its all the special headed chrome/plated ones really.
            Try http://www.bresco.com/
              As well as Peter, I have used these folk. Both very good and helpful.
              Stig Fasteners Ltd for a huge range of Metric and Imperial stainless steel fasteners.
              Polished stainless steel and zinc plated nuts, bolts, washers, screws, self tappers etc., based in Newark, UK. We try to have as much as possible for car and bike restoration.
                It's all the special headed chrome/plated ones really.
                Wait and see what I've found for you Sam
