Quarter light seals,
    Having just read the Mag and Brian's article. can anyone expand on what's involved in changing the Quarter light rubbers please, does it involve removing the door cards and gear boxes or can it all be done in situ
    Ta.
    Ta.
    DONE MINE LAST YEAR
    doors were stripped anyway
    ,you will need to strip out quarter light mechanism as its easier to release the long arm that goes through the box, they get rusty ,there is a clamp that holds this and need releasing
    use plenty of silicone spray or simular
    quite an easy job
    alan
      Originally posted by stag157.7 View Post
      DONE MINE LAST YEAR
      quite an easy job
      alan
      Cheers Alan.
        As Alan says it's an easy job, I also took out the screws which hold the hinge on. Be careful with them - they seem to be brass.
        Brian.
          I second Brian's "be careful" with the hinge screws: there is a fine thread, narrow slot and slim head on them, and they are expensive to replace when they vanish into the "small fastener black hole" which seems to have formed in my garage recently.
          '71 Federal Stag, TRV8, Damson, assorted Jags...
            I've been less than impressed with the replacement rubber seals. They don't seem to fit well and I'm left with wrinkles or ripples on the hypotenuses of the triangle that I can't get rid of.
            Nick
            Nick
              I thought all Hippos had wrinkles and ripples
                Pythagoras didn't. Well maybe when he got old.
                Nick
                  Originally posted by andrew s View Post
                  i'm left with wrinkles or ripples on the hypotenuses
                  i thought all hippos had wrinkles and ripples
                  :d:d:d
                  Ps Why do smiles turn into d's ?
                    Quick question, I bought a pair and thinking about fitting them now, are they handed?
                      I've just taken a quick look at a pair I've got, and yes they are handed. No idea which is which though!
                        Cheers Dave
                        Trying to work out if its too cold to go out to the garage and start or leave it until the summer and do the job in the sunshine
                          Hi Andrew,
                          You should be able to tell which is which as the quarter light glass closes up against the seal inner lip, if that makes any sense
                            I think it will be easier to do when warm. The seals need to slide into and along the grooves and it's important to get them well into the corners to avoid wrinkling. A silicon lubricant would probably help them slide but make them harder to grip.
                            Nick
                            Nick
                              Thanks Nick for the advice
