Evening all.
I just received the Lumination Optronic Mega Spark Coil with the Ballast Resistor (recommended by Rimmers for use with the Lumination electronic Ign kit).
I must say I was none too impressed with receiving the package from Rimmers (who have always come through top notch before)..........
The coil has obviously been wired before, so had the ballast resistor, The coil mount was second hand & damaged & the pre-used box it came in looked like it had been thrown down a long flight of stairs........ but never mind....... as long as it works........ or it will be going straight back.
Anyway........
It came without wiring instructions (although Rimmers said it would) & I have no idea how this ballast resistor is wired in ?
I assume it simply bolts to the coil mounting bracket ?
There is a black wire bolted to the blank side (I assume thats the - side), is that an earth wire ?
So where do I wire the + side to ?
Does it go to the + or - side to the coil ? or does it get used as a bypass between the coil ?
Any help would be great.
Many thanks, Andy.
Anyway........
Many thanks, Andy.
