B post trim
    B post trim
    to remove and to fit the B post trim do you have to loosen the bolts to the T-bar,i know the clips that hold the trim in place are hard to pull out
    dave
    Dave mine came off and went back on without undoing the bolts to the t-bar.
    Joel.
      I had to loosen the T bar bolts on mine, a 50 / 50 chance so far!
        thanks joel
        its because i have the hard top on and though you may have to undo the t-bar bolts
        dave
          Dave I'm with Neil on this one, I had to loosen the 'T' bar bolts on mine too,
          Si
            Hi Dave, you won't have to take the hard top off completely, just stick a lump of timber wrapped up in a load of old rags to protect the paint under the back of it and prop it up a few inches. You only need enough room to get a socket in there.
              dave
              thats a good idea, hadnt thought of that,good thing about this forum someone always comes up with an idea to get over problems
              dave
