Hi all experts,
recently I have asked where I can buy a crankshaft an I received some good tips from kryten and flying farmer. I have digged out my spare crankshaft and found that it doesn't look too bad. The wear on all journals except one is minimal or zero--just the shiny parts and the grey track of the oil groove. The diameter is 44,19 mm i.e. once reground.
On one big end journal for the pistons in cylinder no. 7 and 8 I can feel a slight step with the fingernail/fingertip and detect very fine groove marks. At the step I measure a wear of 0,02-0,03 mm. This wear is only on one side of the double journal (on the center side of the crankshaft), that means the journal is 0,02-0,03 mm oval.
I have tried to make some pictures but it is difficult to show the effect. 1 and 2 are the critical journal, 3 shows a better one.
My questions: would you dare to use this crankshaft again w/o redoing it? Has anybody made experience (good or bad) with such an attempt?
I will survive if I spend the GBP 240 but it is tempting....
Any opinions are very welcome.
Regards Klaus
Regards Klaus
