electronic ignition
    electronic ignition
    Hi guys
    Want to fit the new accuspark electronic ignition, i have at mo the newtronic electric one.
    Question is how do i know if my dizzy used to have single points or double points, as there are two types of accuspark ignitions.
    My head hurts
    vince
    Hi Vince,
    Do you have a problem with the Newtronic! I have it on my car and it seems to be OK (just idle curiosity)
      Hi Ian
      Where it is fixed to the back plate it has gone loose and i cant figure out where it should be, it dosen't screw into any holes it seems to be fixed on a kind of sliding bracket and its giving the engine a bad idle.
      Hope that makes sense.
      vince
        Originally posted by bunny View Post
        Hi Ian
        vince
        Ah, I understand. if it's any help they have a technical department and are very helpful if you call them.
        here's a link; http://www.newtronic.co.uk/new/main.php/contct
          Ok cool thanks will ring them
            Hi Ian
            vince
            I think you will find its supposed to do that to allow the vacuum advance to move it,so it may not be the cause of your bad idle or maybe the vacuum advance isnt connected t it properly.I had one of those and it slides on to slots but is a poor design which has a lot of play in it so like you i binned it in favour of a pertronix however if it is the setup i think it is you will only have a custom baseplate and will need the 2 part standard base to fit your new ignition to.If it looks like this you will need a new base plate.
            Cheers Steve
                Hi Steve yes thats the one, ok something else to find lol
