HI , Am working on removing all the underseal from the car , spent the weekend doing a single arch , 90% was solid as a rock , but there was enough dodgy areas caught just in time to make it worth the work , I noticed them seemed to be absolutely no seam sealer applied so plan to put some on . The question I ask , is do I apply directly to the surface ? , or do I put it on after I have applied the planned coat of Rustbuster 121 epoxy mastic ? , or even is inbetween coats best ? . Is there an established rule for application ? - Advise much appreciated - Cheers Steve
