Hi there, wondering if anyone can diagnose a wee problem that has surfaced. Couple of weeks ago on a wee shoot around the island, i saw that my voltmeter was showing the voltage off the scale, into the red. Usually it sits at 13+ volts, and is usually steady. It soon came down again to normal and i thought little of it, but kept an eye on it. However, it happened again next time out and is now happening more frequently. It's now happening every time i drive and appears to be getting worse. Should i be looking at the voltage regulator. any ideas welcome. cheers, Jools
voltage irregular
Mine went up into the 15v + region when I was on a trip to Belgium. Luckily I made it back to the UK okay and assumed I'd be needing an exchange alternator
Staginhiding gave me an old bust alternator and I was pleasantly surprised at how easy it was to swap the voltage regulator and all's been well ever since.
Originally posted by martin View PostHi Jools, the Mk2 has an all-in-one alternator, the Mk1 has a separate regulator, if you're not a dab hand at sparks, it's a new alternator I fear. Martin.
I'm ok with wiring diagrams etc but when it comes to any more intricate electrics I'm normally flummoxed but this was one job I managed easily.
Thanx for the replies fellas. I have replaced the old mk1 Alt with the Mk2 one with the inbuilt regulator. I intend to check all wires and earths before looking at the Alt. Julian, i agree with you, i reckon i could change the regulator. Where, however, can i find one. If it is the alt ,i may contact the supplier as i would expect to get more than 7000 miles in 18months before needing replaced. cheers jools.
Originally posted by jleyton View PostA year ago I'd have totally agreed with you however, having successfully and relatively simply changed mine on a Mk 2, I would, humbly, beg to differ Martin.
Hiya, the Mk2 should have the Lucas 18 ACR, but as with the Mk 1 1/2 I expect there'll be some overlap..
