Hi all,
I have had my Stag now for about 5 years now, but at the end of last summer I noticed coolant being forced out of the expansion overflow. A quick compression test and revealed the head gasket failure. so the heads had to come off. When I finally got them off ( what a job ) I noticed that the large inlet / outlet from the water pump appears that it should be divided in two but the dividing metal is corroded away. This passageway in the head is combined into one.
On the face of it this does not seem to be something I should worry about, but what do you guy's think?
Kevin
Kevin
