Brake fluid loss
    Brake fluid loss
    Evening All
    This evening as I opened up the garage to put the stag away I noticed a significant pool of what appeared to be brake fluid on the floor. I checked the reservoir and sure enough the level had dropped in the rear most chamber. Upon closer inspection I discovered a trail of fluid from where the master cylinder meets the servo. The trail then lead down to the front chassis leg where it was busy softening the paintwork
    Am I correct in thinking that the master cylinder is buggered? I see LD Parts are out of stock of their sleeved cylinders.
    Bruce
    Originally posted by Rubce View Post
    Evening All
    Bruce
    Yep, unless it from where the reservoir joins to the M/Cylinder.
      Hi All
      I fitted a new master cylinder to the Stag yesterday. When I removed the old one it became very evident that it had been busy leaking fluid into the servo and the engine bay
      Bruce
        Bruce quite an easy job to replace the seals just done two for myself brought new seals from peter at ld and the correct right angle long nose snap ring pliers on e bay .
          Hi Glenn
          Perhaps I will buy a set of seals and fit them and then retain the old cylinder as a backup spare.
          Bruce
