Yesterday I just pulled the Charcoal Canister out of the engine bay. I want to remove as much as possible of this system as I can, but need some advise to do it right:
Thank you for any help!
- I removed the Canister and routed the vent from the engine straight to the manifold. I guess this is ok?
- Attached to the Canister sits what, according to the repair manual, is the Running-on valve. When I disconnected the two electrical connections to it, there was some sparks, even though the ignition was off. I guess this is not correct (and I have probably found out why my battery drains...). What triggers the Running-on valve (oil pressure I believe)? Do I have a sticking relay maybe?
- The running-on valve was connected to the rest of the vacuum system via a T-piece. If I have understood the function of this valve correct, it should stop the car by routing vacuum from the carbon canister to the float chamber and therefore stopping fuel from entering the intake? I have a Ford carburettor on mye car and, and the vacuum line just plumbed into the rest of the system so I guess it is OK to just plug it?
- There is a Expansion tank in rear next to the fuel pump, the top fitting of this tank is in fact broken, so the tank is now wenting inside the boot. Do I need the expansion chamber, and should I just route the vapours to the engine bay? Maybe put a filter on it there?
