Cooling Fan: is this one cheap?
Originally posted by Klaus Schlueter View Post
personally, I would stick with Kenlowe or Pacet....................no connections with either.
Jeff.I only do what the voices in my wife’s head tell me to do!
Originally posted by KOY 23 View PostI'm with Jeff and Wilf on this. The fan does not come on often but when needed must work. Chinese c**p has its place but not here.
Local rad repairer loved the through rad fixings. He sold many cores where these fixings had been used.
JohnI only do what the voices in my wife’s head tell me to do!
Hi
I bought a "bargain" fan a few years ago, it was reversible but it was useless when running in the opposite direction to how it was designed. I'd make sure it is designed to run the direction you need it, either push or pull.
Info here:http://www.pacet.co.uk/choosepacet.php
Stevesigpic
My Kenlowe 14" HD 2-speed fan came with a choice of fixings. The through rad ones went in the bin and I used the plastic items that allowed fitment onto steel bars that were attached to the radiator mounting bolts at the top and bolts through new holes in the rad support panel at the bottom. I know some people don't approve of drilling extra holes in Mr Triumph's finest creation, but to my mind it was the best option. It means that the radiator can be removed leaving the fan in place:
IMG_0026.jpgIMG_0023.jpgIMG_0024.jpgIMG_0025.jpgDave
Originally posted by singapore stag View PostTalking about cheap....isn't this a tad expensive, What is it? gold plated or what?
http://www.ebay.co.uk/itm/16-UNIVERS...item519f7e7e63
Interesting result. I am not after a cheap cooling fan--I have already one from a Peugeot 405 Break from a scrapyard for some €. Works perfect in connection with the 2 side walls and the home made cowl. No problem driving up the mountain roads in the summer heat.
Klaus
Originally posted by Klaus Schlueter View PostInteresting result. I am not after a cheap cooling fan--I have already one from a Peugeot 405 Break from a scrapyard for some €. Works perfect in connection with the 2 side walls and the home made cowl. No problem driving up the mountain roads in the summer heat.
Klaus
[ATTACH=CONFIG]20662[/ATTACH]
I see you are using that new waterless coolant as well Klaus
