turbo
    turbo
    has any one fitted a turbo to a stag v8
    dave
    Surely you would need more than one?!?
      Isn't there a You tube with a green Enginuity car,or is that supercharged with a blower..??
        Yes it's been done.
        I remember Richard Lane of Brighton Stag's did a turbo conversion to his car, before he went over to the Rover Engine. I'm talking the late 80's so a long time ago.
        Twin and single turbo possible, using the single both sides feed the common turbo of course.
        Packaging the usual problem, not a lot of room!
        Supercharger easier, and cooler.
        Tony Hart of HRS has fitted a supercharger recently which is well documented, an eaton screw type. I've always though a Rotrex centrifugal type could be fitted.
          This is about the same question that I have seen with my other V8 car, a Porsche 928. There are several options that has been utilised on the 928:
          - 1 or 2 turbos in front of the engine. This means redesigning the front of the engine to place a intercooler and a radiator far ahead to make room for the turbos
          - 2 turbos low on the sides of the engine (this is not doable on the Stag
          - 1 turbo where the mid muffler is placed. This may not be doable without ruining ground clearance
          - 1 turbo at the rear. This may not be doable without ruining ground clearance also.
          My bet would have been 2 turbos in front of the engine or a single under the boot.
          Kirsti & Ian in Norway
            Originally posted by mjheathcote View Post
            ..... an eaton screw type.....
            are those the ones known in the trade as Camerons ?
              Very good, on good form as usual!
                excellent very droll
                  Lol. Sharp as a knife
                    Makes an Eaton Mess when they blow up
                      I saw a stag fitted with twin turbos at Stafford showground some years back, I can't remember what sort of fueling it used but do remember the owner saying it used mapped ignition and produced about 240bhp
