If anyone is attempting a refurb/recon of their hood frame, I have some tips here that I hope they will find useful. The fist is a checklist to make sure all the main issues are covered. Following that is a short explanation of each item on the list. Sorry if some of the terms are not self explanatory; I will try to finish my sketch of the frame which might help ID the parts.
HOOD RECON CHECKLIST
- Front X-member angle
- Front X-member welds
- Front X-member threaded inserts
- Front X-member corner hinges
- Rear bow curvature
- Rear bow torsional stiffness
- Rear bow captive nuts
- Main Bow straightness, longitudinal
- Main bow lateral
- B-post seal plates
- Side catch striker position
- Side rails in line
- Pivots
- Bolts/nuts tight
- Torsion springs
- Front x-member must be at correct rake angle to ensure good seal and alignment of pins with sockets.
- X-member welds (spot and other welds) must be good especially at ends.
- Threaded inserts for fixing chrome levers must be secure and have good clean threads
- Corner hinge joints to be free to move.
- Rear bow must match curvature of car body
- Failure of spot welds on rear bow causes loss of torsional rigidity.
- Captive nuts can come loose or fall out of the rear bow
- Main bow can bend forwards or backwards, causing poor b-post seal and side catch misalignment.
- Frame can move sideways off-centre casing poor seal alignment.
- B-post seal plates must be straight to ensure good seal alignment.
- Side catch strikers must move in correct arc to locate with catches. Apart from being affected by 8, distortion of the J-legs can also cause an alignment problem.
- The front and rear side rails must be in line with each other when frame is fully up/forwards. The frame must not arch up (or down) in the middle.
- All pivots must be lubricated and free to move without binding, and not as slack as to rattle. Shims can be changed to get correct adjustment.
- All pivot bolts and locknuts must be tight. Bolts should first be tight to shoulder before nuts are locked.
- Springs must have sufficient tension to balance weight of hood, and the tops part must remain secure in front of the frame tab.
