Hi there, Just touching up a few chips on the arches , Using nab/19 from Rimmers , however it appears to be a bit grey / beigey - just not as white as my body colour - appreciate colour changes over the years & I know earlier in it's life it had a partial rear respary - However I notice Rimmer also sell "Leyland" white - wondered if there was any difference ? , is one whiter than the other ? , could my car be Leyland not #19 ? - Anyone got any experience with this - Would have thought with all those white stags out there someone can point me in the right direction, any advise would be much appreciated . Cheers Steve
Which White ?
Hi Steve, your best bet is to take your car to a trade paint supplier and get it properly matched, they're usually quite happy to mix and pack an aerosol for you, or bigger quantities of course. Your chances of finding a match off the shelf are pretty much nil. Ask for cellulose, much easier to use, and forgiving of mistakes.Martin.
Thanks for the advise - I may well end up having to get a mix made up - Have done a bit more research - appears Leyland white was only used on late models - 1977 onwards - mine is a 1976- 77 , the year in which they used both !. The question is still out there , is Leyland white, whiter than #19 ? - Cheers Steve
Hi Steve,
mine is November 76, and it's white 19, creamy white, i have original panels on the car and a few patches of leyland white where it has been touched up by PO,
you can see the difference side by side if you look closely, the original white is not a bright white if you get what i mean, it's close to an old BL colour called Arum white, you cant get this anymore either, when i spoke to wards they said the closest match for touch up is old english white.
hope this helps
Alan
hope this helps
Alan
If that's correct, it'll be Old English White 1, Old English White 2 was too creamy. Martin.
Originally posted by martin View PostIf that's correct, it'll be Old English White 1, Old English White 2 was too creamy. Martin.it's saturday an i'm on the JD an coke, bet your on the wine too
dont think we will get far hahhhahah
i know there are 2 different whites, i had some mixed by a friend an he asked which one it was, white or creamy white
Alan
Originally posted by stag888 View PostThanks for the advise - I may well end up having to get a mix made up - Have done a bit more research - appears Leyland white was only used on late models - 1977 onwards - mine is a 1976- 77 , the year in which they used both !. The question is still out there , is Leyland white, whiter than #19 ? - Cheers Steve
regards,
Raoul
My local paint place told me there was a triumph 19 pre 74 and a triumph 19 post 74 (though its now listed as rover old white and rover new white. apparently the older white had a touch of black tint in it but is otherwise the same as new white. I would guess that the touch of black would add a bit of a grey/creamy colour than new white.
As others have said, most paint shops can colour match now and that is probably your best bet for a decent match
added (actually that might be pre and post 73 not 74.)
