mark 1 and 2 door locks.
    There has been a lot of questions re mark 1 door locks being fitted to mark 2 cars. I have done a little bit of detective work and what people seem to have over looked is the body number and commision numbers refer to different things. The body number T.....LD under the bonnet refers to the order that the body shell was built painted and trimed at
    liverpool. The commision number was put on the car as it went down the final production line at Canley where the mechanicals were added and the car completed. As the body shells did not go down the final assembly line in body number order but as required ie RHD white car it was selected from the storage and put on the final line to be completed. Thus mark 1 door locks were fitted up to body shell T21183LD for UK and T20987LE for USA. Thus a mark 2 car can have mark 1 trimmed shell that did not go down the line before mark 2 shells. Most other mark 2 parts that were changed on mark 2 cars were bolt on so were easier to fit. Hope this helps identify cars that should be mark 1 or 2 and of course the mark 1.5 bitzer.
    My chassis No. is LD 24497 O first reg. August 1973(No tax from next year). The numbers under the bonnet are T 23083 LD and 23191 LD. My car was not the fully MK 2 as it had many MK 1 bits including the doors. I needed a new interior door lock and handle and ordered a MK 2 only to find my mistake when trying to fit it.
    Rod
      I took the numbers from the Triumph Stag parts book. Seems a bit weird that mk 1 bits like locks on shell that late. I can understand easy change bits like wheels, t bar etc as they are reasonably easy to adapt. I know Triumphs policy was to use up old stock as much as possible that may account for mk1.5s. When the tooling for cam covers wore out they than used the same tooling for both covers thats why some say Triumph upside down.
        What ever happened, Mk1.5 cars were built on Mk1 body shells. you can't physically fit Mk2 locks to a Mk1 without cutting out and replacing a part of the B pillar
          As I said previously according to Triumph last trimmed Mk1 shell was T21185LD for UK so hopefully all mk 1 and mk 1.5 are numbered lower. I cant speculate if numbering is correct why higher numbered shells are equiped with mk 1 locks.
            I'm saying nothing
              Originally posted by staginhiding View Post
              I'm saying nothing
              Have you found the photo's yet Sam
              I suppose, the cars in question (Mine, Rod's & DJT's) could have been put together in 73 using painted but untrimmed shells
                I haven't Ian,they are in a trunk in the loft,forgotten about many years ago..We are meant to be clearing the loft this year so I guess I wont be looking until then..
                  Along with dozens of others up to the launch of the 4th Sanction cars (LD30001).................
                    Found another one. Pimento Stag, recently changed hands locally and in Andy's workshop. Currently on a private plate but originally registered in November '73 on an M plate. Body number T23*** Comm number LD24***BW and has Mk1 locks. car is all original with full history from new.
                      mines a 73 on m plate but i have mk2 door locks and boot lid
                      dave
                        dave
                        what is your Com no Dave
                          ian
                          i thought some would ask that,i dont know
                          i cant open the passengers door to near the fence,and log book at my mums
                          dave
                            ian
                            dave
                            A picture of your dash panel (if it's original) will show if it's a 1.5 Dave.
                              just got the log book out oct 73 LD24852 will that mean i now don't have to pay tax
                              dave
