stag not starting when cold
    stag will not start when cold. can be started when holding hand over carburettor intake
    starts and runs fine when hot. choke discs are in correct position, float pipes adjusted
    correctly, suggestions please
    Float pipes ?
      sorry, should have read float heights
        Gotcha, sounds as if it's very lean, providing your ignition is OK. Martin.
          How does it run when its warm? it does sound like its running weak or the chokes not working for some reason..
            [QUOTE=staginhiding;221172]How does it run when its warm? it does sound like its running weak or the chokes
            When it is warm engine runs well. C/o is 2.5%. H/c is 400.
            Ignition timing 12%.
            When starting from cold no attempt at firing
              If the enrichment levers are being operated correctly, then because covering the intakes effects starting, there is a possibility the enrichment mechanism is not working, maybe the holes are blocked (Alan will no doubt comment on the unlikelihood of that)?
                I am thinking about putting the float heights a little higher [now set at 17mm] has any
                one had any experience of that?
                  That will probably put your CO up over the limit and waste fuel.
                    The choke mechanism has been dismantled and thoroughly cleaned and reassembled
                    with the large cut out on the disc close to the fuel supply hole. A mini vac pump was put
                    in the carb body choke outlet hole (i.e. piston removed)
                    With chokes off no fuel was drawn through. Chokes on; fuel was drawn through so
                    assume that is now assembled and working correct.
                    When engine is running if chokes are pulled out it enrichens the mixture enough to
                    make the engine start chugging.
                      Is your coil 12volt starter boost working?
                        I have just checked voltages on car and coil hoping V Mad had found something i had overlooked
                        but unfortunately ignition on coil is 8v cranking 9v so it would appear OK
                        My current thinking is heavy build up of coke on inlet valves absorbing fuel or valves not seating correctly
                        I have access on Monday to a Snap on cylinder efficiency tester [puts a measured amount of air in cylinder at T.D.C and measure the amount of air loss] and see what the results are. Has anyone ever tried this?
                          I have just checked voltages on car and coil hoping V Mad had found something i had overlooked but unfortunately ignition on coil is 8v cranking 9v so it would appear OK
                          Your coil voltage on cranking should be boosted up to full battery voltage to aid starting. 8 volts is not going to give you the best spark.
                            I feel for you I am having exactly the same probelm and am now out of ideas and patience its even been to a specialist.
                            after biting the bullet even after spending a good few pounds changing a lot of items no start cold.
                            Stumped completly now with no options just wont start from cold but when and if you can get it going starts on the button warm.
                            Really really dont know where to go with it at all.
                            Hope you have better luck than i have had.
                            items done to date.
                            Plugs
                            Leads
                            Choke cable both chokes working spot on
                            carbs tuned & checked few new o rings fitted, checked c/o 3.50 timing is spot on
                            various pipes done vacuum pipe elbows
                            diaphrams
                            earth lead cleaned checked
                            rotor arm /cap
                            mk2 so no ballast resistor
                            If anybody can help would be fantastic No mechanic myself thats why it went to a specialist still no cold start
                            All the best.
                            Cliff.
                              Speedy - you are describing a leak down test which basically checks the valve seating.
                              Have you done a compression check yet?
